scokill
- Rowlett, TX
Our engines are easy to turn. You are indeed better off with two identical batteries for ACR use. Why not use 2 Deep Cycle or 2 Dual Purpose batteries? That way they charge about the same, and will give you better performance if they deep discharge.
I've had one of my batteries get so low that the amp for my tower speakers shut off. I did a test and switched to just that batter to start the engines. No problem. You really don't need a battery designed for CCA for these engines. I switched to two deep cycles years ago.
