AZMark
- Phoenix, AZ
- Limited S
@Mainah
1) An enormous difference. Base forks and shocks just aren’t great.
Much better valving & tuneability beyond just pumping it up more. They’re also usually stiffer (against flex), especially if you get bigger stanchions, which makes things more predictable and smooth.
2) How long are you thinking of going? At 150 or so of good suspension you have a bike that’s still very nimble and can take big hits combined with decent technique.
3) Maybe the 29” wheels. You could try some 27.5” bikes.
I had the opposite experience but same thinking as you. I’m 5’11” and started on medium thinking that it would be more maneuverable. I went to a large of the same model bike several years later and I was much more comfortable.
I’d do a fitting where you buy it and make sure the seat position and other adjustments aren’t going to be maxed out for you on a medium.
4) If you’re that in tune with the bike and what you are feeling from the suspension then unfortunately you are screwed and you aren’t going to be very happy with compromise. I’m the same way.
It won’t be 3x better for 3x more cost but it will be a very big difference and you’ll be happy vs feeling like your bike is holding you back.
5 bonus!) carbon is awesome. It damps things more, it’s super stiff and super light. Not fragile in any way for riding but you do have to be careful about things hitting it. I put a tiny crack in my frame from the bike falling over in the perfect spot but it’s never caused me issues.
Go do a demo day if they do those where you are. Or rent some to try.
Im partial to specialized but that stumpjumper evo expert for $6100 looks awesome. I’ve rented Pivot Mach 5.5 and 6 up in Utah a couple times and they are very nice bikes too. The rear suspension felt similar to specialized despite being different designs.
Rented an Ibis Mojo as well and I didn’t like it quite as much. It felt a little less smooth but could’ve just been tuning.
