84rzv500r
- Lower Keys MM29
yep, however there are some other things... I had to make my own shims to set the impeller spacing off the stator housing cause I built Frankenstein pumps... so check the washers under the impellers are installed correctly and fully seated
re: Beatings in housing, I think you put a straight edge across the stator housing without the cone on and measure the depth that'll tell ya if the shaft is pressed all the way
