Mr1 question
Wisefam22
Lake Lanier ga
06 230... doesnt have high output on the top of engine. Max rpm is 10200. Are those the non ho or HO is their a difference in the max rpm between the 2?
or check for a sticker under the air cleaner on the starboard side,
What's the speedometer and tachometer look like? It should read High output in capital letters on each gauge if it was so equipped from the factory.
If your hitting 10200 it’s high output. From what I hear the non is 7500. I believe that’s true.
My 2005 Ar230 was non HO and hit close to 10,200. the HO had longer stroke higher compression pistons not a big difference in performance. There is a label on the motor if the sticker didn't fall off
These all had the same motor there was a lot of hype on the HO but when tested on the boats was almost no difference. You will loose more performance with a few dings on the impeller or gaps in the silicone from the ride plate to the hull. My 2005 non HO and the same tachs. You have the non HO and dont worry about how much better the HO would be. I would have 9 people on board and pull a wake boarder with no problem. My friend had the 2006 HO we tried them back to back.
2002-2008 FX 140
2003-2008 FX 140 CRUISER
2003 and 2005 SR 230
2004-2006 SX 230
2004-2006 AR 230
