Ronnie
- SF Bay Area
- Limited S
Didn’t get much more done today but did manage to paint the front brake calipers on the SUV/boat tow vehicle. I can’t do the rear calipers in the garage the back of the SUV is just a little bit too tall.
View attachment 218022View attachment 218023
No,Were you swapping out pads?
No,
Just cleaned and painted the calipers.
Just painted the back of the pads that are exposed. When the brake pads are replaced the back goes back to the standard color. I’ve painted the calipers on about 10 vehicles over the last few years. I just follow the process in many YouTube videos...and your pads! ?
When the time comes to replace them, it might be worth it to run a utility blade along that paint to avoid peeling any paint off. That's why I thought you might be swapping pads - paint it first, pull the pads and any paint on them, let it dry, and then slide the new ones in
The Expediton has been awesome. This is my fourth one and is a 2012 Limited EL with the 5.4L V8. Two wheel drives are rated to tow 9,200 lbs. and four wheel drive 8,900 lbs. not sure what the new ones are rated to pull but was given a 2019 Max as a warranty loaner a few years ago, it had a twin turbo six cylinder that could out accelerate my 2010 Limited. I did not get to tow with it but with 12 forward gears and dedicated tow settings I have no doubt it would have towed by boat fine. If my current Expediton died today I would have another one in my driveway tomorrow.How do you like towing with the Expy? I have ‘16 with 3.5L Ecoboost and towed well. She says a little with the AR240. Just ordered Sumo inserts should get them later this week.
The non towing mpg of the ‘16 is a lot better than the older versions. It seems like I only get ‘16 mpg when not towing. This was the case with my ‘04 and ‘10 as well. Thankfully, this is not my daily driver. It’s dedicated to towing the boat and/or people moving with a capacity to seat eight legally including the driver.I like towing with the ‘16. Normal driving get 24 mpg highway. Towing I got ~12 mpg. So, you mpg or power but not both ?. The 6 speed tranny works well so far for towing. Very good acceleration. I put 93 octane when towing long haul trailer or boat and is very smooth.
