RyanTexas
- SX
Hi guys, I recently joined to look for help in my Yamaha jet boat.
Its model is: 2008 Yamaha SX210
The problems:
The overheat warning light on the port side engine is on, when putting it in the lake at idle speed for 10 min, the pissing holes pumped hot air, but only droplets of hot water came out. While it is still tied to the dock, I gave it some gas to 4000rpm to see if more water coming out of pissing holes, they remain the same, only droplets came out. The weird part is the boat didn't move at all, at least the rope has to be stretched at one end.
I towed it back home and inspected:
+ both jet drives ran just fine, they spin according to the gas I put in.
+ Intake water screen and hose from screen to the 1st T connector, no clog at all.
+ the water hose feeding to the pissing holes, also not clogging at all, I blew both of them it using my mouth.
+ When running the port engine off the flush hose, it ran fine, no overheat warning came on, but the pissing holes also have no water coming out.
+ Oil also half changed to the correct level, when the engines are leveled.
Can someone kindly show me a direction to resolve this? Mechanics are busy and they won't get to my boat for a couple of months.
Thank you,
Ryan
The problems:
Thank you,
Ryan
