mpbassett44
- Los Angeles
- Limited
This weekend I took the boat (2016 242 limited) to Lake Havasu. I bought the boat in September and I've only had it out 4 times.
Problem #1....Every time I pull the boat out of the water, I remove the drain plug, and water pours out for almost 1 minute. My older boat was always dry after removing the plug. How is so much water getting in? I always check the engine compartment out on the lake, and I only see a minimal amount of water. I turn on the bilge and nothing. Where is all this water hiding? I don't think it's leaking from the cooling system due to the water is cold.
Problem #2....After an hour on the lake, the check port engine light came on. It was a solid beep, plus the light. I called the mechanic, and he said it should be ok to drive the boat back to the dock on both engines, as long as it ran ok. No other lights came on, and everything sounded and ran normal. How worried should i be?
