2nazt
- Port St. Lucie, FL
- Tidewater
- Other
So opened up and started my scupper swap out today, as soon as I grabbed my aft scupper is crumbled apart. I was just thinking thats okay, thats why I'm changing it. Well I went to loosen the drain line from the deck and upon loosening my hose clamp, almost no pressure. That fitting fell apart too, so off to partzilla to get one in quick. Good thing I still have 13 days left of my work rotation with no chance of getting the boat wet. Gives me time to install the swim deck cup holders, rule 1100gph bilge pump, tow valves, swim deck speakers, and Guest onboard charger along with NoCo thru hull plug.
One question what would you use to cut the 6.5" hole for the speakers, a rotozip?
Thanks
Andy
Thanks
Andy
