@Jgorm @Brad460 how do I check for or know what detonation looks like and can you please clarify what that is? Thanks
When I figured out that my ECU's were damaged as mentioned in a previous thread I changed them out with two high output used ECU's I found on eBay. I cross checked the part numbers and they were in fact the 2005 Yamaha sx230 High output ECU's. My boat is the 2005 non high output version but now it has high output ECU's controlling it and definitely providing me with much more power and 1k more rpms per engine. I was under the assumption from reading other threads on here the only difference in the high outputs is a different air to fuel ratio and a different intake / exhaust set up to allow for more air passage. Correct me if I'm wrong
@Beachbummer @Neutron @swatski how do I know if I have installed the plugs correctly? I thought it was pretty straight forward but could you please elaborate your procedure or tips to avoid improper plug seating?
I do it like this: firstly clean the threads with a shop towel wrapped around a screwdriver, apply anti seize to the new plug threads, apply dielectric grease to the part of the plug where the ignition coil will make contact, then I make sure the washer that came with the plug is all the way up and not in the threads, proceed to hand tighten the plug, back out the plug a quarter turn a few times while screwing it in to make sure the antiseize gets applied evenly, then after it's hand tight I use the ratchet to tighten it a quarter turn. Put the ignition coil back on and that's it
Also y'all are right, I used the irridium plugs because I want the best for my boat and thought they'd be stronger but now I truly see there's no difference in the regular and the irridiums, if we're going to be changing them out every season like recommended than it makes sense to use the regular cr9eb plug.
@Gym I'm running 87 octane as specified in the manual, I also add the required amount of stabil marine 360 with each fill up and the required amount of Lucas fuel injector cleaner.
What fuel additives do you guys like to you use? Some say it's snake oil some love a specific brand, I'd like your opinions and suggestions since I'm new to the game
Today I went out on the Hudson River again and the boat preformed really well and smooth, now that it's back in my warehouse since it's raining for a couple days I'll check all 8 spark plugs I installed 36 hours ago, got two trips out of them so far I'll keep you all posted on how they held up.
I appreciate the replies and help
Attached are a couple pics from my trip
