I'm bringing this thread back to life. I have a 2006 AR230, the threads where the fuel pump braces bolt into the tank are stripped and causing a big leak. A fuel tank out of an 07-09 AR230 is the same, updated fuel tank. Correct?
Because I am not experienced in it. I'm not opposed to it, if it will work long term. I do have a fuel tank from a wrecked 08 AR230 just sitting around, so it wouldn't be too big of an expense. I really don't want to have to cut the floor up and fiberglass it back down.
Are you sure epoxying it will work and hold up long term? What materials would be needed? Where could i get the epoxy?
Do you have a 2006 or 2008? I know you said 2006 but your sig line and profile say 2008. If it's the latter, can't you just remove the factory hatch instead of cutting? I've never had mine off but it sure looks big enough to get the tank out of from the looks of it.
