Need a recommendation <Bluetooth adapter>
Geiger41
Egg Harbor Township NJ
Boatless
NA
NA
Can anyone recommend a 3.5mm Bluetooth adaptor that I can plug into the 3.5mm aux jack. Then sync it up with my HTC ONE smartphone. I want to listen to Pandora but get tired of using the 3.5mm wire connected to both the phone and the jack. Then I could be mobile with the phone and use it around the boat and from the beach depending on the area the signal covers/
Hey Glassman what kind of distance can you get with your phone from your boat?
HTC makes one that I use that supposedly automatically connects to HTC phones. I have a Samsung and it works fine. But I do have to connect to it. It has a battery but needs to be charged via USB. I just leave it charging all the time. Wish there was a better hardwired solution I could throw behind the helm.
Part of the reason I got the HTC adapter was it used this aptx codec for better sound. It is very good sounding for bluetooth. I'd say you generally hear compression artifacts from source material before the adapter.
http://www.amazon.com/gp/aw/d/B00CAYAIL0?pc_redir=1398583860&robot_redir=1
I haven't used it in the boat yet, it worked very well at I'd say 25' in my home, but I'll test the distance this afternoon and check back in.
The max range of any Bluetooth device is about 10 meters or a tad over 30 feet. At that range though you're getting plenty of static. A realistic, line of site, range is 18-20 feet. You can experiment with this if you have a Bluetooth earpiece for your cell phone.
If you find a nice bluetooth that happens to have rca plugs, you can simply buy an adapter cable with male RCA to 3.5mm for a few bucks. I did that with my Fusion MS-BT100.
Does the wet sounds device have to be used with a wet sounds head unit?
Doesnt look like it. Its standard Bluetooth input what 3.5mm Aux output. I like it, but would like to also retain use of the 3.5mm Aux on my dash. Suppose I could just plug this into the dash aux, however would prefer a more finished look. Wonder what would happen if I bridged the two Aux sources to the same input on the HU? Doesnt sound like a good idea but I dont really want to install a switch or something. Maybe a guy can find a decent mountable switch that doesnt look out of place.
How is the sound quality with Bluetooth? I love the idea, but get picky about how clear my music is. I already am not happy using the headphone jack for the input. It is not as clear and full as synching an Ipod. The convenience of the Bluetooth would be great though. I too hate the extra wires hanging around the helm.
I guess it really depends on what type of music you listen to and how loud. The Bluetooth is slightly muddy but not so much that it sounds bad. Try it!
I think I will. You guys have posted up some fairly inexpensive options, worth a try. Thanks for the info.
