Robert_o
- Cottonwood, AZ
Boat was running fine , but just died, now I'm stuck in the water ! 2013 ar1
90
90
Where are you? I just pulled into Laughlin nv. Are you on lake Mohave?I was on plane, yes I've been playing music for about 5 hours . It does crank but it won't start! It is full of gas.
I am at lake pleasant , wish I was at Mohave !Where are you? I just pulled into Laughlin nv. Are you on lake Mohave?
Hitting wakes sometimes upsets the cleanout hatch which triggers the cleanout switches. But usually the engine wouldn't crank if it was those. But like @ToddW850 was referring to, have somebody hold down those switches by hand and try to start again.I did the kill switch , what fuses?and where are they? I was hitting wakes ,
