- Florida
- Other
- Other
Disconnect the cables from the nozzles / rotate the wheel all the way to the right/ place a piece of tape on top of the wheel/ rotate the wheel all the way to the left/ place a piece of tape on top of the wheel / now rotate the wheel to point both pieces of tape as close as possible to the floor. Now place a piece of tape on top of the wheel / the wheel is now centered / lay a straight edge across the openings of the nozzles and have them flat against it with someone holding the straight edge against them while you readjust the cables to the hole in the nozzle steering arms . After that readjust the rudder with the nozzles and wheel the rudder should be at 90 degrees to the back of the boat with the steering wheel in dead center. do not do the other thing as that was for an old and different style boat it would not work on this boat
