razdazbraz
Calling on the automated ballast experts @swatski @KXCam22 @jcyamaharider @dan144k .
So I am about to pull the trigger and automate the ballast on my 2018 AR 210. Throwing the pumps over the side and all that is just too time consuming when I can automate this and fill on the go.
I've studied through all the builds of the above mentioned so I think I've got it down to how I want my system to work.
I will be venting (visual fill overflow) and draining through the side hull fittings so there's no need to physically watch bags fill or drain and can kill pumps accordingly. May add in the float switch & vacuum switches for auto shutoff on both fill and drain. Trying to not have to worry about burning up impellers constantly.
I really just want this to be as full proof and simple to use as possible. I realize the install is going to be the toughest part but I can handle that.
Any opinions would be appreciated before I pull the trigger on this.
Thank you!
Thank you!
