I'm guessing, whereas the fuel tank is lower than the carbs you probably have an electric fuel pump supplying a constant fuel pressure to the carbs. Whatever the carbs don't use is returned to the tank via the tube bypass.
No pump inside the tank, only on the engine. Just wasn't sure if that could be part of the issue. I think I need to just do a full carb rebuild on both just to rule that out.
