Excited to be taking delivery of my new 210 FSH Sport. Old line boat dealer recently picked up Yamaha boats, so I’m thinking they may not be aware of some of the pre-delivery quirks. What should I be sure to check before driving off?
Having read a lot of posts I wonder if the anchor locker drain on the 210 is like the older 190’s - not thru hull
Any concerns with the standard trolling motor bracket?
What extra goodies do you suggest - I’m adding a Garmin.
Thanks in advance
Congrats on getting your new boat!
Before driving off:
-Check the white gel coat inside the boat everywhere for nicks and scratches.
-Check the exterior gel coat for nicks and scratches.
-Check all around the exterior jet pumps.
-Check the engine compartment for any loose wires and or any obvious issues
-Check battery compartment and battery connections.
-Check all switches, and their associated devices for proper function.
-Check inside of the center console compartment, pull the curtain back and visually inspect the back side of the gauges and wiring for any obvious defects.
-Check that the bearing buddies on each wheel are full of grease.
-Pull the access panel located on the clean out tray and inspect the plumbing and such, have small flashlight handy for this.
-Check around the base of the wind screen for nicks and scratches.
-Verify the dealer has checked the oil of the engines, there are tags on the dipsticks that are to be removed by the dealer.
-If possible have the salesman take you out on the boat for a test, be sure and leave enough time to do the engine break in period.
-I’ve not had any issues with the anchor locker drain
- The stock trolling motor bracket works well... except that some have reported it flex’s enough to leave a Mark on the gel coat.
The extra goodies depends on what you are going to use the boat for. My signature line has my add ons, I’m very happy with my hummingbird Solix and Rip Tide Ulterra with I pilot. Also I’d put on a dual bank battery charger like a MinnKota PC 220 and hook that up to the OEM start and house batteries. Once you add a trolling motor you can decide what brand/ type of battery charger you want to install based on your battery choice.
