Mainah
- Chapin, SC
- Limited S
Batteries are supposed to have a common ground wire bridging the negative terminals. If the small black wire is hooked to ground but there is not a common ground for the batteries a similar issue will occur. Provided all is wired right, tight, and batteries did not get harmed by sitting in discharge then it may be time to take it back to the dealer. I would likley check all harness connectors are tight as well in the engine compartment and behind the helm.
Good Luck
Good Luck
