mahlzeit
- LX
Hello, recently bought a 2003 lx210 and none of the gauges worked. I'm fine on fuel and speed by now, but having issues with the tachometers. Bought Faria gauges with hour meter (THC617B) and hooked them up. One of them showed some erratic life (needle would go way up and then go back and forth) but now doesn't show any RPMs at all. Other gauge didn't show anything from the get go.
I tried to check the signal and wiring with my limited knowledge. I am pretty sure the gauges are hooked up correctly. They have power (lcd hour meter comes on and shows 0), also backlight works as expected.
When checking the rpm signal with a Hertz meter, it shows about 400Hz on a freshly started idling engine (which seems to high, as this should translate to about 8k rpm if I'm doing the math right) fluctuating quite a bit. When increasing the throttle slightly it actually goes DOWN and stabilizes around 200Hz.
Quesitons:
Video of signal: Streamja - Simple video sharing
![IMG_20210411_092341.jpg IMG_20210411_092341.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/148/148522-fee231961241f9ee044267011639979f.jpg?hash=_uIxlhJB-e)
Quesitons:
- Does the signal seem correct?
- If not, what should it show? Where can I check? What could be wrong?
- could a faulty tach signal damage the gauges? Neither of the needles shows any life, even though there is clearly an (erratic) signal
