mat_l_1
- Scarab
- 165 G
Hi jetboaters...
Recently found a 2016 165 Ghost that needed a new home. So I sold the family 2010 pontoon and decided to buy a fun boat. Took quick on water test drive and it appeared to be solid before I bought. Wanted to see if there is a list of stuff I should do for a good 'shakeout' to make sure I don't have any surprises this summer - so I can be comfortable with the family taking it out.
Boat details...
Trailer -all lights checked out OK. Note - looks like the left bunk had a 'hard reload event' and they added a 2x wood underneath as extra support
Boat Lift- will need to swap the pontoon setup to a jet runabout setup..
While trailering I started without the aftermarket snap on cover installed - however the whole back engine cover popped up while driving. I originally thought that I must not have shut it hard enough, but on the second event where It popped open, I pulled into a service station and installed the cover - no issues after that for another 150 miles
Just because it is a 6 year old boat and things wear out - I do want to make it the best experience for my family i can.I'm not a boat mechanic, but not afraid to disassemble, reassemble, and torque a wrench on cars...
After making it home - I trailered to the boat launch and I did another quick solo run yesterday keeping RPMs and speed lower ... noticed - small amount of green antifreeze in bilge and low reservoir. Let it all cool off and after a quick tighten on a few clamps (thanks to this forum for the advise and link to pictures) - and next quick run - no green in bilge. Will keep an eye on the coolant (i did top it off with premix green)
Today I will give it a run w full throttle and watch for more stuff (again looking for water in bilge / ski locker / elsewhere) based on what I've read in this forum.
Thanks in advance & happy boating.
Boat details...
- Base level 165 Ghost 61 hours.
- Scarab factory tower added.
- Has aftermarket cover
- Prior owner was saying the stock bilge float kept sticking and would drain battery.. so he added battery shutoff and different Bilge.
- I may want to add back in the OG bilge and have 2x bilge ready, but need to figure out 'where' that one actually 'is hiding' / 'was hiding'
- Is there an adjustment on the latch to make it more secure?
- Does anyone have a good checklist of things they would verify - stuff to check out and in water / running/ at rest
- Symptoms to watch for
- Items that should be replaced / checked- just because stuff wears out.
