Is connext nmea 200 or 0183 compatible or it's own thing? Look at the gps signal input to the screen if it has one. You guys with the fancy boats will have to look. IF it has a puck for the gps you may be able to integrate. If it's built into the unit, you need to look to see what inputs it has available anywhere. Look under the dash and stuff.
Looks Great! Can you advise on the sizing of the piece of starboard you used? Also what sizes fuses did you use for the radio in the fuse block (did you keep the stock inline fuse)?
