scopeusa
- Providenciales
- SX
I have been off the grid due to medical issues but now thankfully they seem to be fixed.
A friend has a 230 AR which is left sitting for months on end, out in the Caribbean environment. Needless to say with no maintenance and not being run up he has problems. This time he returns and hooks up the battery and when he switches either key nothing, completely dead. The blower motors and lights work OK. This must mean that the main fuse is good. I looked up the wiring diagram on a 2004 factory manual and could not see any secondary breaker after the main fuse. My SX230HO provides power to the depth gauge when any of the three kill circuits are open, lanyard, jet port hatch or throttle. Has anyone had an ignition switch go bad. The battery is fine and stays fine with a 75 amp load applied. I am wondering if he reversed the battery polarity by mistake. Does anyone have any knowledge as to whether battery polarity reversal damages anything I would assume that Yamaha would provide diode protection? If there is no power to the hot side of the ignition switches any ideas? I thought that each system was completely independent.
