No power when turning ignition keys on
I have the same issue with my SX210 2007. It has blown the 30 Amp fuse. I replaced it with the spare 30 Amp fuse and it blew that as well... anyone have any good explanations to that...? The boat has been rock solid since I bought from new...
We have been using it consistently and it has never before given us problems. I have changed oil, filters and sparkplugs regularly. I had to change the key assembly earlier this year, as one was broken but that's literally the only 'non standard' maintenance issue I have had.
We took it out this morning and everything worked great. We had a break of an hour or two where the boat was being battered a bit around by the waves but nothing serious and then when I wanted to start the engines again the the little bib that normally comes when you turn the key to the starboard engine to the middle position didn't sound and the engine didn't crank. The port engine started and was working normally.
I have been going through the A) Engine wont turn over at all list and found the blown 30 Amp fuse as mentioned and it blew the spare one as well... any help is very much appreciated...
