jtink
- SX
So 3 weeks ago I took my 2012 210 sx to the dealer. I was getting an intermittent check engine light at start up or low speeds.
They could not get the check engine light to come on, they tested the thermostat (s) and found both engines were running at 160 degrees and stats should open at 140. That must be your problem. Since there were no stored codes.
Took the.boat out for the first time after repairs, check engine light immediately, turn off wait then start again, all is fine.
Took the boat back to the dealer. This time they got the light to come on, then able to connect to software, said starboard engine no wake switch is failed.
They then switched the starboard and port switches and the check engine light followed to port side.
My question is, it sounds like this is the problem, however I see alot of people on here say the no wake switch is usually a sign of voltage issues. I have two batteries on a switch, I have tried running on either battery and on both batteries together and still have the alarm.
Thoughts....
Thoughts....
