Adrian @ JB Solutions
- Tampa Bay, FL
- 252SE
Once you get that answer you then want to find an amp that will be able to produce at least 60-70% of your total rms wattage. You don’t want an amp that pushes more wattage than your speakers can produce.
I had to pull this out because this is very misinformative and could cause someone to blow their speaker. Without getting too technical - you want to get as close to RMS as possible, if not over. The reason being is the speaker won't perform how you want it when you under power it, because of this people have a tendency to turn it up more. This causes the amplifier to clip. Clipping causes extreme heat, which is the primary cause of speaker failure. On the flip side, if you over-power a speaker with a clean signal, you will often find with the correct filters you can run at least double the RMS with no issues (and it may out-perform your expectations). Very rarely does overpowering a speaker cause it to fail. Also note, with extra power you can always turn down your gain so your amplifier isn't working as hard. Overheard is ALWAYS a good thing.
