2kwik4u
- Buffalo, NY
Well..... big stuff today.
HVAC is fixed. New head control unit got me pointed in the right direction. Had to tear open the blend door actuator and recalibrate the encoder by hand. Wasn't hard, just a little tedious. So temp control is back. Mode select is working. The new linkage from Dorman had a goofy tooth profile and was causing it to bind on dash mode. Retrofitted the old linkage to the new actuator and reinstalled. That solved that issue. So......all the HVAC is fixed and working as it's supposed to. WooHoo.
Now, still have a coolant leak. I didn't replace the push to connect fittings on the heater core, and I think one is still leaking. I have two new fittings, I was just lazy. I'll have to get back on that here soon. It's a tiny leak so it's low priority.
Dash is still apart. I spent too much time upside down fixing the HVAC, hopefully I can get that back together this week.
Biggest part though......tagged and transferred. Means I officially own it now right?!?
First time this trucks had IN tags on it!
