Oil Change 212X
I could be blind, but i dont see any filter models i this post :(
Or, there could be a messup on the FAQ...
Oh, [USERGROUP=3]@Administrative[/USERGROUP] ! Looks like there is something amiss with the FAQ at https://jetboaters.net/faq/#faq-1 about the oil filter and plug numbers. I know there was a list up there at one time. I contributed for my boat (2012 AR240):
Oil filter Yamaha 69j-13440-01-00, Fram PH3614, Wix 51348 Mobil M1-102, K&N HP-1002, Motorcraft FL910S
Edited to correct the K&N number, @Scottintexas ...
Oil filter Yamaha 69j-13440-01-00, Fram PH3614, Wix 51348 Mobil M1-102, K&N HP-1001, Motorcraft FL910S
@Scottintexas
@EatShiporDive I don't know for sure what engine your boat has and I'm to lazy/busy to research it at the moment, Your manual should tell you what oil filter and spark plug to use, you could also check amazon or Yamahasportsplaza.com to get the Yamaha filter # and then cross reference it. many of us use mobil 1 or KN filters, use whatever your comfortable with
Murf [U]/ tdonoughue[/U] if we're talking about the MR-1 link, it is broken, it's to bad because that was a good "how to" with pictures, I think I tried a year ago to track down anyone that had saved it offline but didn't have any luck,
if we're talking about other links (I didn't check them all) some are still broken from the software upgrade,
Thanks, @Scottintexas . I was not referring to the MR-1 link, but the FAQ at https://jetboaters.net/faq/#faq-1. If you look in the index on the left, the first two entries in Parts Info appear to be repeated, but the first one only partially. In the text, the partial one is then spaced out oddly and the second instance is normal. I thought that was perhaps because something was missing showing more part numbers or something...
