David Martin
- Punta Gorda
- SX
Hey guys I thought the new folks might want to do future diagnostic so I'll pass along a little knowledge that might help someone down the road/lake. My boat is running rich due to excessive idling and Blackstone confirmed this in the oil. Blackstone also confirmed low metal were and not to worry just change the oil. My oil was a 5 on fuel contamination their test the average of 2.5 as a high on all oils they see. So I just changed oil and wanted to share a diagnostic approach that will help most people.
First the best engine diagnostic STARTS at a good PLUG read nothing will give you more info than this as to engine health. Hear is my Port and Starboard read. The Starboard reads top left to right as you can see all plugs read rich but the number 2 and 4 plug are at lease twice as rich. Post read is left to right and all plugs read rich with the #2 as a total off the scale rich. Now this info along with the oil analyses is starting to add up.
Now a lot of things can cause a overly rich cylinder 1 broken ring , bad valve seats, both of these lower cylinder pressure causing poor flame fronts, bad coil packs also poor flame fronts, bad computer, wiring and last bad injectors(my fav so far)........that leads to the SECOND diagnostic test COMPRESSION TEST this test eliminates a lot of the above possible problems. My Starboard engine 210,210,207,210 PSI, looks excellent to me. Port 210,210 205,203 PSI, Nothing wrongs with these numbers.... so long broken rings,valve seat leaks....this test leaves coil packs, injectors computer EMC and wiring.
Not that's where I stopped and since Blackstone Lab gave me a low metal for my engine and they Start quick and run smooth I WILL NOT BE PULLING THE ENGINES out of service but will correct the cylinders on the naughty list soon.
Next week out comes the multimeter/omh meter to complete the diagnostic of the coils, injectors, wiring to computer(emc)from both of the remaining parts to find out which one will be left standing as the PROBLEM CHILD now all these readings will get written down in my service manual giving me a great snap shot for future reference.
HOPE THIS HELPS A LITTLE in you future diagnostic approach ......... I never look for what's wrong I test for what is good and that usually leaves you with the problem. Now my Gut says (injector) corrosion......... I feel electronically the injectors and coils will be within specks because I purchased the boat last year its was a 2013 with 23 hours on the clock, it sat most of its life (none use is a recipe for corrosion) the 4 injector spray holes and spray needles are my best guess....but the meter will tell.
Sorry for the book!
Sorry for the book!
