greenwood
- Lake Geenwood
- Scarab
- Other
Just removed the oil filter on my 2015 (165) with the 150 HP Rotax.
The cap is attached to a rod with a metal sleeve and a bolt at the bottom which does not allow me to get the cap off to replace the small dime sized o ring.
Is this normal?
Also when I tighten the new cap down with the new filter I can see the top red o ring which makes me think something is not right.
Can anyone advise?
When I watch the you tube video's of changing the seadoo oil filters the cap comes off as a separate part allowing you to replace that small o ring on the shaft below the cap.
Thanks
Is this normal?
Can anyone advise?
Thanks
