ibaran
- FSH Deluxe
Hey all! I have a 2018 210FSH and just changed the oil and oil filters. Took it for a blast and I get a Low Oil Pressure Alarm on my Port side Motor. Oil level is fine. everything is dry. You can run the motors indefinitely up to 5000rpm and when you cross that threshold the ECM looks at the switch and throws the alarm.
I don’t run the main engines a ton. There is literally 85hours on these. I mostly troll with my bow mount Minnkota.
1. Anyone see anything like this before?
2. Does anyone know the part for the guage and where to attach it if I was going to see the actual oil pressure?
3. Does anyone know where this oil pressure switch is located and what the part number is to replace it? I see the assembly is 68V-82504-00-00
