Dough
- Lake Barkley
- Limited
Wow! Staying away from those impellers!
Did you have difficulty removing them? I would clean the metal sleeve they sit in. Quite often they get a salt or mineral build up. I use a coarse scrubble from the kitchen sink with some soap or some fine sandpaper. Then a little silicone spray. Wipe the excess spray off. Make sure the slots that the dogs lock into are clear of debris.[USERGROUP=9]@HELP[/USERGROUP] I am not in water but trying to get plugs back into clean out ports. Lubed the plug as well as port... it appears the gasket has expanded from previous owner and won' set back in.
Any idea? Could I used rubber band around it to try and get from the plastic part into metal?
I knew this wasn' the thread since it' not boating season and on the water but needed immediate help as it was about to ruin our weekend camping trip.
Thanks for quick responses
