ncnmra
Jetboaters Commander
- Ontario, Canada
- X
Its a 7mm hex bolt. They are the slide pins on which the caliper slides. I was able to buy the correct hex bit to remove them. All the brake parts look in pretty decent condition. I lubed up all the sliding mechanisms, and put it back together, but the caliper is still sticking. I was able to push it apart using a C-clamp. Anything else it could be?
I'm pretty sure that the actuator is ok, and is releasing. The other wheel (driver's side) unlocks just fine, and there is only one line going to the breaks. It looks like the passenger side is the master, and the driver's side is the slave, with a hydraulic line running across the back axel.
Any thoughts or ideas would be greatly appreciated.
