BKirish
hi all- been an owner of an AR240 going on our 7th season now and never posted but have used this forum extensively and it has literally saved me thousands. So I just want to say thank you to all.
Latest issue: had numerous intermittent port engine overheat advisories. Thought it to be debris, but it continued to get progressively worse yesterday on the water causing us to single engine it back to the dock.
Overheat again 30 min later, 2 min into flush. crap.... jet boater forum all evening looking into all the potential issues that could be the cause. Range of issue: simple-super complex. This am started with the simple stuff; Topping off battery charge now, switched spark plugs from Port/Stbd (new ones every season, and new set of 4 on order), pulled out the thermostats on both motors and one open, one closed (the one on the overheated motor closed.) I am hoping this is the dealio/culprit. thoughts?
I put one of these on order last night based on this site and my "strategy" this morning was 100% garnered from this site, thx again (assuming i have successfully identified the offender that is)
brian
brian
