Hose pressure is minimal at best. Go run the boat on the lake, and watch the pee holes, make sure you have a good stream from both the thermostat and the exhaust loop.
This is another reason we tell guys not to try to flush both engines at the same time...water volume on a hose is minimal, even if you have pretty good pressure. Glad it is ok!
Yes..water pressure! My water pressure at home is pretty darn good. I made a y adapter for the flush and tried both engines at once on my old sx210. It overheated and I have never tried it since.
Water pressure is a big deal. I asked the dealer if I could tee off the hose and run both engines simultaneously and he said absolutely not, there's not enough water pressure to do that. I also had a friend's boyfriend help me one day: I started the engine and told him to turn the water on "All the way." The engine kept stalling. Turns out he only had the water partially on, he didn't;t know what "All the way" means!!!
