Very good topic, also interested in this
Here is my recent communication wit Riva Racing from greenhaul they've mostly work on PWC.
Q:
Hello I came across your website and I am interested in maptuner or dynojet product , would like to flash ECU on my Chapparel Vortex 243 VRX 2016 Jet Boat with two BRP 250 engines ,see-doos runs same engines , will I be able to see any difference in performance with the products you sell , do I need to do any modifications in addition to the flash to get any results. Thank You
R:
Sergey, the best answer I can give you is it may be possible for you to tune the engines on your boat with the MaptunerX. It would depend on which software version is on the ECU's on your boat. In the worst case scenario, the ECU's an be sent to us so we can read them with our special equipment. Once we read them then you would be able to use the MaptunerX on the boat.
I can tell you though, the entire reason to reflash the ECU's is to be able to supply fueling for higher boost levels. This is where the gains come from. So, in addition to reflashing your ECU's you would want to install these supercharger upgrades
https://www.4-tecperformance.com/index.php?main_page=product_info&cPath=18_63&products_id=1536
If you have any questions let me know. I'm happy to assist you.
Jerry
Q:
Is there any instructions on-line on how to locate ECUs from this engines?
R:
The ECU is bolted to the top of the intake manifold.
See the diagram on this page of our store. The ECU is item 9
http://partsfinder.onlinemicrofiche...9&b=12&c=0-INTAKE-MANIFOLD/THROTTLE-BODY-ASSY.
Thank you
Jerry
Q:
How does the ECU Mail in works , do you guarantee its not going to get messed up by you guys connecting and modifying maps . Thanks
R:
Details
For the mail in tune, order the service from this link in our store and mail your ECU to the address spelled out in this link you order from.
https://www.4-tecperformance.com/index.php?main_page=product_info&cPath=180&products_id=4690
RIVA has never messed up an ECU reflashing them. They use highly specialized equipment to read and write to the ECU, but rest assured if something was messed up you will be taken care of.
Thanks
I am debating if I should do this
