Mainah
- Chapin, SC
- Limited S
Warning!!! Technical content contained within. Skip down to the Verdict section for the quick read.
Today I tested the stock Polk PA4a as a second step in tuning in my sound system. The first step was testing the outputs of the iPhone 7 I am using as the source. I did not grab shots from the iPhone but suffice it to say that that it put out a little less than 1 volt, has no clipping to the top end and is a very clean signal. This matches what labs have observed in their testing. The oscilloscope I am using is not lab grade but I did install custom firmware that I coded with a custom configuration for this purpose and then bench calibrated both the hardware and software. So again not lab quality but for this purpose already a bit overkill.
I tested the "front" RCA outputs with the speaker harness disconnected and everything set to flat except for the loudness which I had to turn on to get decent voltage out of the head unit. For all tests documented in this post the iPhone volume was turned up to max and I was using a professional calibrated signal generator app outputting a 1k sine wave test tone that yes I also tested and validated. My comments related to distortion are from observing the frequency and mvDC in real time (with a buffer). The more it fluctuates during the test the worse the signal and I did not turn on min/max/hold as I like to observe the change in more detail than the screen allows.
Bluetooth -
I have commented that my human ear observations had me believe that bluetooth in the headhunt was less than stellar and I was not wrong. The chipset is pre BT 4.1 so that is not very surprising. Even a clean 1k sine wave had distortion at the helm and got worse further away from the head unit. Clipping occurred above 95% head unit volume (1st screen shot is what clipping looks like, sawtooth pattern as opposed to wave). The max rms voltage with no clip was 2.32v.
USB-
I had commented that I thought USB to be best. I discovered there is slight distortion likely because the DAC chip the head unit employs causes it. The reason I may have thought this is because the headunit achieves 2.88v at 100% volume with no clipping.
Aux In-
Using the iPhone dongle (hate that it is even needed) I got a pure signal all the way up to 95% volume and 2.88v rms. Above 95% there was clipping.
Verdict-
2.88v was the max output voltage without clipping which is well shy of the perfect 3.7v rms with a 1k sine wave test tone. In other words not complete junk but not that good either. JL amps as as example will handle 4.0v rms without issue and since amp increase at a constant rate based on the gain a weaker input voltage means less output will be achieved. I am going to have to ponder what I am going to do about this wether that be getting a WS420, a completely different head unit or something else. In the mean time even though Aux In was proven best given slightly less distortion I am going to stick with USB as it is more convenient, will achieve the same max pre clip rms output voltage, and there is no clipping at 100% volume so can't go wrong by cranking it as long as the amps are tuned right. Bluetooth on the other hand will mean less volume without clipping and more distortion so while more convenient at times it is better not to play at high volumes with bluetooth on this unit.
Closing-
I am sure there are some experts that are going to poke holes in this. Keep in mind that there was more testing done but stopping and taking screen shots and then posting all of it takes time not to mention gets too deep in the weeds for most. Notice my other channels are set to off for these screen shots to keep things clean. I am not an engineer and just a guy with an electronics hobby. If I did make a major error please do let me know. Stay tuned for my JL amp tuning results with sound spectrum monitoring to fine tune and record db levels.
Bluetooth -
USB-
Aux In-
Verdict-
Closing-
