I completed step 2 of tuning my system yesterday afternoon. First a couple of notes about the data. My portable mini digital oscilloscope samples at a 72 mhz rate stores up to 4096 frames in memory computes buffers the data to the buffer setting reads computes frequency based on x and y the renders the screen. This is important because you will notice in the screenshots an exaggerated view of the wave form and when when the buffer is set such that less than three peaks and valleys are in the x,y then frequency won't be computed. USB input was used for the testing/tuning with everything tuned flat. The screen grab saved file numbers you see are something I have to manually enter and I was keeping track with pen and paper. I did arrow over a bit too much at times so the sequence may be a bit off from what is described by those are the right screen grabs for the description.
Polk PA4A Speaker Level Outs-
90% volume with USB input was the max pre clip with a 1k test tone netting 9.4 volts. I did not get the screen grab but also no clip at 40 hz. Turning on loudness caused clipping and distortion at 90% so going forwards I am going to keep loudness off. The wave form is rather clean which I found surprising but my cabin speakers can handle much more voltage. I have 6 speakers tuning off the Polk speaker level outs (bow Polk MM651, swim deck Polk MM651, stock tower tweeters) given that I prefer those areas to be a bit quieter and the speakers are receiving full bandwidth (except the towers tweeters) I feel good about this.
JL M400/4 with 80k High Pass Filter-
I have 4 mid cabin Polk MM 651 running off of 4 channels. The first thing you will notice is that the waveform is no longer clean. This is being primarily caused by my oscilloscope picking up the PWM distortion of the signal inherent in all Class D amps. Amplifiy the noise already in the signal is also a part of this. Keep in ming this is exaggerated given the sample rate, sample size, and buffering. 14.4 volts was the max pre clip voltage (I am using a 10x probe at this point to see more detail on the screen so 1.44*10 =14.4). I zoomed in on the wave form in the second photo by increasing the buffer. The speakers could handle more voltage but I am satisfied with this.
View attachment 70956 View attachment 70957
JL M400/4 with 120k Low Pass Filter Bridged-
I am running two Polk 1040MM subs of of two bridged channels each. As noted above the distortion is being primarily caused by PWM and the oscilloscope is picking up on it because of the setting I am using. 40hz at 33.6v (again 10x probe was being used) was causing a very slight clip seen the the leading edge of the valley and trailing edge of the peak. I increased the buffer to see the wave form in more detail and fine tuned this to 30.4v. These subs could handle a lot more and maybe someday I will get a more powerful amp for them but for now I am happy with this.
View attachment 70958 View attachment 70959
How it sounds-
I did not want to tick off the neighbors for too long but I had to hear how it sounded. I was quite happy with the balance across the lows and mids. The high seemed a bit bright so I may need to turn down the treble in the POLK head unit. I found that a cranked 39.5hz test tone was just about resonant frequency for the boat as a whole and it gave me a mild sick to my stomach feeling. I could actually see the boat hull oscillating in spots without having to look too close. No bad vibrations of anything playing a few different tracks. For this year I will be happy with it and will see if I go another step up down the road. I still need to some sound db and sound spectrum stuff out on the water so I don't tick off my neighbors and the hull being in the water may change the sound dynamics a bit.
