Yea, I kinda get the "half tank in" premise. The issue is I'm towing through a charging desert essentially. The distance is far enough that I'll be sneaking up on 5-10% reserve capacity if I take the boat with me. My internal Boy Scout won't let me drop below 20% SOC or so on a trip. My use case is kinda weird because I have a really high energy usage (because towing), and I'm going through what amounts to a charging desert. There are some 50A 240V plugs available and some slow charging stations, but nowhere to really get a good quick charge within my circle of travel with the boat.
So in this instance I would have been around 55% SOC (assuming R1T with 135kWh pack and 800Wh/mi usage on ABRP after leaving on 100%) when the ER run was triggered. I dropped the boat and left it, and hauled butt to the ER in the Q7 this time. Hospital was 45mi away, and we made it there in a shade under 40min. I suppose I would have done the same thing in a Rivian, and still been able to make the trip without incident. Would have been a little slower trip and closer to the edge on energy usage had I left the boat attached.
I REALLY like the Rivian, and I REALLY want to get an EV that tows. I'm having the hardest time letting go of the flexibility that comes from an ICE in a charging desert. I'm struggling with the "Just because I CAN, does that mean I SHOULD?" arguement.
Side note response: golf cart was stationary when accident happened. Older brother had pulled into playground, parked, and 4yr old tripped getting out, did a barrel roll and bonked his head on a larger than normal piece of rock. Belts are a good idea, no doubt, but wouldn't have helped him here. Just klutzy moment on rough terrain. We should probably be a little more vigilant on letting them travel outside viewing distance with the golf cart, no arguments there either, however they both handled it fairly well. 10yr old stripped his shirt off and applied pressure, then drove cart back to camp (like 6 spaces up) to get help.
**EDIT** Here's my plugshare map. Filtered to 50kW and higher outlets.
Red circles is home.
Blue circles are Ramps (We were near top left blue circle on Saturday, it's the easiest to solve)
Highlights will require a charge. Others can make it there and back on 1 charge
Assuming: 800Wh/mi usage and 90% SOC departure.
**EDIT#2**
I 100% understand that all of this concern goes completely out the window if we stay the night somewhere. Even a 110V charge overnight will get us that small amount to easily cover the trip home. The highlighted spaces are a shade over 2hrs away, so they're on the fringe of "day trips" anyway for us. If we overnight (in particular at a campground with RV hookups) we're in good shape.
It's really |...| that close to being completely ironed out for me and for me to make a reservation.
