aquilotti1
- Boatless
- NA
- Other
- Other
Im close to closing for a 195S leftover 2023 model brand new Yamaha jet boat. Went to look at the boat today and it had some issues like some of the mat were pilling off and the front window plastic fairing was missing a piece. I know it’s been sitting around at the dealer for a year so things like that could happen. The batteries were dead and so on. The dealership would obviously fix all that before closing the deal so I’m not too concerned. Now I just had a few questions, this boat will be used for saltwater down here in Florida. My biggest concern is corrosion. What are the best steps to take to keep the boat safe from corrosion? I understand flushing the engine and anti corrosion spray on the keel and engine compartment but is there anything else I should be aware about? Also I’m planning to trailer the boat but I wouldn’t mind taking the boat down to the Keys and leaving at the dock for 3 days, according to my salesman I shouldn’t leave this boat more than a day straight inside the water or that can cause issue. Meaning I could never rent out a slip to keep my boat in the water like I see most Outboard boats do down here at the marina. Is this a jet engine issue? Could I take the boat for a weekend getaway and leave it in the water for 3/4 days without having serious problems? And let’s say you take it down to The keys and use it for 4 days straight without flushing out the engine would that be a problem? Especially if you’re in a location that doesn’t provide a hose. Or you’re meant to flush the engine every single day you’re out on the boat? Thanks for hearing me out. This is my first boat so I’m just overly concerned .
