- Royal, AR
- SX
I thought it would be good to have a thread listing ideas that Yamaha could easily implement to improve their products. I will start with three. What would you guys suggest?
1. Add an aluminum I-Beam trailer with torsion suspension option or replace the galvanized trailer with it. The galvanized trailers are much better than painted for salt water use but still rust over time. An aluminum trailer would be better for salt water use and for towing regardless of where you boat. It would also provide an upmarket appearance. The torsion axles would remove the unprotected springs as a common point of failure.
2. Make carpeted flooring a dealer installed option. Some love it, some hate it. Many buyers will replace it over time. Most of us would prefer the option to install whatever flooring we would like.
3. Build the tachometers in Connext boats into a removable panel to allow the installation of a 7" chart plotter or remove the tachometers entirely and simply have a blanking panel. Tachometer values on the connext screen are sufficient. We really need plotting and it would be nice if it did not block the forward view.
