- Lake Ray Roberts, Texas
- Boatless
- NA
- Other
- NA
How many times have you found your oil filter so tight you couldn't remove it? You new boat owners know what I am talking about! Shops are especially bad about overtightening them. I bought the 14 sided, correct metal filter wrench for the Yamaha filters, and it won't even hold tight to remove a filter if it is overtightened. The easy way to remove one of these is to just take a normal wide band oil filter strap style wrench, and put a piece of medium grit sand paper between the filter and the wrench band. You will need to fold the sand paper where it has grit on both sides...or next to both the band and the filter. It gives enough friction to hold while you loosen the filter!
