Removing lower seat cushions
Mike Clark
Germantown, ohio
So, I want to remove the lower seat cushion located on the engine hatch cover of my 2015 240 SX, the left side was installed slightly crooked and as much as I try, can't overlook it. I want to drill new holes and realign.
When I open the hatch I have three screws with nuts showing and have removed the nuts, and pulled up on the seat, the front edge seems to pulls up but center section appears to still be stuck on pretty tight. Does anybody know if there is adhesive as well or maybe the studs are just relly tight in the holes? Don't want to break the bottom of seat. Any one removed theirs for any reason?
Did you figure out how to remove the bottom cushion? Looking to do mine... Thanks!
