Ronnie
- SF Bay Area
- Limited S
I am highly anticipating the insulation results. I was looking at my hatch yesterday and just realized that OEM insulation on the main part that you are about to tackle is only 1/2 inch. I thought it was the same 1” + like where you still have insulation. Weatherstripping around the perimeter (which you’ve done) was still a huge improvement and should be the first thing anyone does.I continued reskinning upholstery skins yesterday and looks like k will be doing the same today. I also installed mounting pins for the engine hatch foam/sound absorbing material (I.e., sanded the ware under each pin, glued the pins in place with heavy duty adhesive and out tape over each pin ), test tinted the center window and painted the gps antennae cover, pics are pending on the last two things. View attachment 200899View attachment 200900View attachment 200901View attachment 200902
Well done RonnieGetting it done a little bit at a time. This before work this morning I secured the swim deck seat backs to the hull. All I had to do was put 20 washers and nuts on. It took an hour and a half including getting access under the foam in the engine compartment and behind the swim deck speaker. I installed the cushions and the sound absorbing material on engine compartment hatch after work, thankfully that only room a few minutes including taping the edges of the new cushions (to protect them while I worked the piece in the ground).View attachment 201100View attachment 201101View attachment 201102
Beautiful Ronnie. All your hard work paid off. Nicely doneAll the new upholstery skins have been installed, along with the new “D” seal along the engine compartment opening. I got the boat on the water for the first time this season yesterday. I am all but done, just need to tint the windows, add a pin stripe and a few other little things buy for the most part this project is complete. Here are a few more pics.
Evaluations of individual upgrades and modifications will follow soon.
View attachment 201409View attachment 201410View attachment 201411View attachment 201412View attachment 201413View attachment 201414View attachment 201415
You seen it several times in my pics. My man cave is only half of a two car garage. My wife owns the other half.Can’t wait to see the Bat Cave!
finally, the extra detent/stop on the throttle arms does not seem to be doing anything as far as increasing rpm’s at all
That may explain it, that is, I thought the extra detent would increase the rpms a little more and give the no wake mode more range. Knowing what I know now, I would not have burned the time it took to switch out the throttle assembly,Hey Ronnie - Nice work, looking great!
I believe this detention was what Yamaha called enhanced thrust assist, or some other name, but in essence, it keeps the buckets slightly closed to deflect more of the thrust down for better maneuverability. The RPMs will remain low (no wake speed).
Don’t forget to get tint that is “half as much” for the drivers side, so that when you double it up it will be the same as the other windows.You seen it several times in my pics. My man cave is only half of a two car garage. My wife owns the other half.
This sets up a problem for me to tint the boat’s windows. The boat won’t fit into the garage / under the door, so I will need to tint it outside, which means early morning before the wind starts up or on a really hot day when there is no wind. That three flat windows I should be able to do unit in an hour total. The curved windows should take me about an hour each, two hours for the drivers window since I plan to do front and back.
Now that I I have already installed the new throttle assembly I plan to just use it as as. Now there is just an extra detent to push though before throttling up.@Ronnie doesn’t have the late model jet nozzles that direct some of the reverse flow to the sides, which as I understand it is part of the TDE. As Will at JBP described it, using the no wake mode switch to increase the rpm’s while the levers are in the TDE position is what makes it work better, and it does work when cruising along using both throttles in unison and the steering wheel. For me, I’ve found the different amounts of thrust from just barely open to TDE to full idle ahead work great when trolling, and I’ve used TDE at full no wake mode speed [HASH=6996]#3([/HASH]?) great for taking people for tours around and close to the shore, kinda like the jungle boat cruise at Disneyland when I was a kid.
