MilesPrower
- FSH Sport
The majority of my boating trips involve running out before sunrise or coming back after sunset. I have two boats, and I got tired of trying to remember the layout of the switches at the helm of each of my boats. On my 255 FSH, the switch labels were impossible to read at night without turning on a light. The standard Map Light, even in red mode, was too bright and caused a dangerous reflection on the windscreen. Therefore, I decided to swap out all of the FSH's switches with backlit dual-lamp switches that I purchased from New Wire Marine. Now, when I flip on the Nav lights, all of the switch backlights turn on, which allows me to positively identify the switches without ruining my night vision. Enabling any single switch turns on its second "on-indicator" lamp at the bottom of its rocker, so I can easily discern at a glance which systems are on or off.
My (very dirty) helm, before I replaced the original Contura V switches:
![standard-buttons.jpg standard-buttons.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/231/231391-2f54abfff0dd28ac9240a0e8b4d5c716.jpg?hash=POuaJe4Kmt)
My (slightly cleaner) helm, right before sunset, with new backlit Contura V switches and rockers from New Wire Marine:
![new-buttons.jpg new-buttons.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/231/231392-968b84b08c7c46e0df0d981ca54825c4.jpg?hash=F2Rm32XvNn)
During and after sunset:
![helm-sunset.jpg helm-sunset.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/231/231397-240cfab2eba58aa2025e55f309447125.jpg?hash=KTU1nrNoLK)
![helm-almost-dark.jpg helm-almost-dark.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/231/231398-9e2fb80d35810a9b1100f07e735060ee.jpg?hash=Yi2lpRlmKT)
The sunset, as rainclouds were slowly rolling out, was gorgeous:
![view-from-bow.jpg view-from-bow.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/231/231399-b7fad9e18a6ff4e9386cee2dc6b0fa83.jpg?hash=iZOOblF5Xj)
Navigating a tight channel on my moonless run back:
![helm-dark-channel.jpg helm-dark-channel.jpg](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/231/231400-44118baf8f6ac0c878412ad687671097.jpg?hash=tlZ9s-Gb5q)
To achieve the backlighting, I bought dual-lamp Contura V replacements for every switch (including the No Wake / Cruise momentary-toggle and Blower rocker switches that aren't visible in the photos), except for the Nav/Anchor and Horn switches. For the Horn switch, I just repurposed its original "on-indicator" lamp to a backlight. The Nav/Anchor light was already a dual-lamp, and it didn't really need a separate backlight. Most of the replacement rocker covers come from one of the standard cover kits from New Wire Marine, but a few of them (like the Trolling Motor and No Wake ones) are custom covers.
To supply power to the backlight and on-indicator lamps, I bought a pack of crimp connectors that I wired and inserted into the original quick-release connector housings. A few of the connector housings I had to fully replace, because their replacement switches had an alternate pin layout, but I had no problem sourcing the crimp connectors and housings from Mouser. If you have an appropriate crimp tool and a pin remover, wiring and replacing the connector housings is dead simple.
Pulling the old switches, re-pinning the connector housings, and mounting the new switches took me less than 2 hours. With that said, researching and purchasing all of the parts required for the project took me many more hours. As with most projects that utilize modular subcomponents, a good deal of nomenclature and part-number deciphering is required (PDF). In particular, my Trolling Motor switch, which operates a remote high-current solenoid connected to the TM battery bank, required careful research. The TM switch's backlight lamp is powered in the same manner as all of the other switches, but its on-indicator lamp is powered separately from the TM battery bank via the remote solenoid — while the grounds for the two lamps remain separate.
I also added foam gaskets under each switch. Without gaskets, the original switches leaked a good deal of water into the helm closet whenever I rinsed the helm.
