drewkaree
Jetboaters Fleet Admiral 1*
- Central WI
I measured my new 3/8" fitting and it's .650 on the threads....you were measuring the shank, not the threads, right? I should be ok.
Measured the mashed in threads on the plastic part. the smooth shank itself is actually thinner than the threads so it sounds like you should be good, and it sounds like the same situation I had, went with a smaller fitting and it slid right in the hole, no problems.
