FSH 210 Sport
- Tranquility Base
- FSH Sport
I would agree that it “may” not be necessary to seal up the clean out tray IF, there is no leakage past the clean plugs and up the tubes, and, if you get rid of that drain that is on the clean out tray as it is totally unnecessary on our boats because we that hose big slots on either side of the clean out tray. Other wise a thin bead of silicone / seal & peel is necessary. Before the O ring at the bottom of the clean out plug well I had installed the JBP mechanical riser which also helped.. that and the anchor locker drain fix-thanks @drewkaree - sealing up the rod holders and cup holders that drained into the bilge, especially the cup holders on the storage pods, these looked like one of those rain shower heads when water was on top of the storage pod, the bilge in my boat was totally dry, except if I use the wash down extensively haven’t figured that one out yetMy tech shared a couple of things with me as I watched him replace the cables.
He counted the turns on the yokes as he removed them - replaced with same number of turns to keep jet alignment.
He had to use some heat on one nut with the O2 sensor wrench. Said it wasn’t uncommon to find one bound up.
When feeding the cables thru from the front storage/helm area, he was careful to not hit the nipple extending up on the fuel pump which is under the access port between the helm and engine compartment. It’s an expensive mistake as the the pump is $700+.
When eyeballing the jet alignment he suggested angling each jet slightly toward the rudder/middle. He said it helps reduce wandering. I have to take his word on this as I haven’t been out yet.
He strongly recommended replacing with OEM cables. He said the aftermarket ones were not very good.
I asked why he didn’t reseal the access cover by the cleanout ports. His words were “it’s not necessary.” Not sure I agree with him, but I will definitely be watching and if it seems like there’s more water in the bilge I can seal it and/or add the JBP riser.
It took him less than three hours to complete the job.
The steering is ridiculously easy now!
I did some poking around and the main issue is that these cables are not the best they could be. The higher end cable systems are filled with grease from the factor and have very good seals on them that not only keep the grease in, they keep the water out. So, folks like @Bugslayer and I think @Dixemon who filled their cables with oil then clamped a piece of hose over the rod that retained this oil have had no further issues. Sounds like an opportunity for an aftermarket product…
Thanks for finishing up your thread and I hope that you get many many hours on the boat this season! Pictures!
