Joshua Miller
- Jacksonville, NC
- 252XE
Yeah that sounds like a software issue...most likely an update will fix it.Just took my boat in for some warranty stuff including this. They read the codes and sent them off to Yamaha. Service manager said its possible they will have to replace the touch screen but he won't know until Yamaha replies.
Got the software update on Saturday. Went from Version P2.1 to P2.2. Fixed the MX reset on the engine instantly.
Thanks! Did you take it to the dealer to get the upgrade?Got the software update on Saturday. Went from Version P2.1 to P2.2. Fixed the MX reset on the engine instantly.
YesThanks! Did you take it to the dealer to get the upgrade?
I didn't really look at it much. Took the boat back to storage after seeing the reset. It is also supposed to fix the stop steering warning from the reverse buckets and computer getting confused. Only time will tell for that one. When that happens I have to do a full battery shutdown to reset the computer.Apart from fixing that issue, was the upgrade related to anything else or any new features that you can tell?
I will try same next time I'm at the boat.My manual doesn't specify but I think it does for my boat...I had trouble resetting mine after my oil change and it didn't work. I think I tried it again the next day on the water and it worked. Give it a try next time you're on the water or flushing and let us know.
