Reverse module error
Did you ever get picture of that relay?
No I've sold the boat. But there's a fuse box in the engine compartment. There's two relays in there that go bad by the battery I believe..
Ok thanks! Ill take a look.
I have a 2018 223 VRX and have had repeated issues with this stupid ereverse since the day I picked it up. This is somewhere near the 5th time I have either had to take it to the dealer or have them come out to the dock to work on this issue. It's getting old.
I would love to find someone who knows enough about ereverse to disable it. It's a pain in the you know what and has led to me not feeling the boat is anyway reliable to take any great distance from home.
If I cannot find someone to disable it, then I am about ready to get rid of it. I am sure others out there feel the same way because I read tons of forums which are filled with ereverse problems.
I have the same issues! I just got this 2018 Chaparral vortex 203 and since the moment I put it in the water I keep getting the stupid eReverse module error! I can not go more than 5 mph and have no neutral or reverse. I have a brand new battery installed and this error keeps coming up. My local Chaparral dealer wont even call me back! Im dead in the water right now. Any suggestions?
Hi guys.
I have a 2019 scarab 215 wake I'd. Also have reverse error codes while idling in forward. Also:
Second drive of the day - after running the blower the battery light came on during engine start and remained on for 4-5 mins. Battery voltage was around 13.1 after blower was turned off but battery light remained on.
After about 5-10 mins of driving at variable speeds the Portside engine suddenly turned off at 6000rpm
The Starboard side engine remained running. Fuel level was at just over half.
The PORT ECU POWER (30) S B+ breaker was popped
Codes displayed were:
U0100
U16BB
U16B9
U16B7
U16B5
U16BD
U16BD
Would appreciate any insight. Also would buying a Candoo code reader help me eliminate some of the electrical issues or at least track them down better?
I ended up taking it into my Chaparral dealer, They replaced the IBR module under warranty, Test ran in it and so far so good!
Hi guys.
U0100
U16BB
U16B9
U16B7
U16B5
U16BD
U16BD
The CanDoo will list and explain what the error codes are and allow you to clear them. It will not eliminate any electrical issues. CanDoo will also help reset the maintenance needed alarm (every 100 hours). Good luck.
Here’s the relays.
Mine wouldn’t let me start engines and showed e reverse module error.
I replaced them all and working fine now.
Here’s the relays.
Where are these located on the boat? Im having the same issue
I think it is one box per engine. Mine (215 ho 2018) are located right and left. But if you open the hatch and have a good look, you will find it(them)
I think I did find them. There are 2 inside a black fuse box with multiple other fuses inside
Hey everyone, I'm a new scarab owner, we have a 2017 195 Open. I'm having the same issue with the reverse module and ordered what I believe to be the correct relays. Should be here Friday. I've attached pictures. I'm going to hook it up to a trickle charger tonight and let it set for a few days then change the relays and see what happens. If I go into override fir the reverse module the "bucket" should move if all things work correctly right? Also, while on the trickle charger do I need the main battery switch turned on? thanks in advance for the help. This has been frustrating to say the least.
Correct. The buckets should move if all is working. And, no, the battery switch does not need to be on. Just be sure to hook the charger directly to the battery.
OK, great thanks for the help.
You have to reset the electric system , disconnect all batteries for minimum 15 hours and connect it again it will run good …..
Attention ALL Scarab 255 twin engine owners I will be contacting Morgan & Morgan regarding a class action suit for this horrendous problem!
We as owners have strength in numbers to demand a recall warranty fix! If you want to join the suit contact me at Sailortrawler@gmail.com I will need names addresses year of boat and if you have spoken to a dealer or attempted repair.
I will compile a list and bring it to the attorneys
Accountability will be the only way scarab will comply!
I look forward to hearing from everyone!
