Theryan
- Minneapolis, MN
- SX
I've got a strange one for you guys. I bought my '12 SX190 last fall, and I'm finally getting around to doing some stuff to it. I noticed that the stereo isn't wired to any switch, and it is always just on/off depending on if I turn it on.
I was considering putting a switch in for it now that I purchased a Blue Sea fuse box and whatnot, but I'm not even sure where the wiring for the head unit even connects to. I'm thinking about putting in a second battery for electronics (not sure on whether or not I'll bother putting a switch in for it yet), and would rather connect the stereo to the house battery (if I do install it), but without having a clue where the wiring goes it's going to be tough.
Have any of you come across this? Did you rewire yours?
AND, second question - as I've been digging around I've noticed that none of the drain ports in the anchor locker or cubbies are connected to any sort of hosing, so if there's water it just drips down on the carpet in the storage lockers. Where are these hoses supposed to connect to if i want to put the hoses in?
Thanks!
Thanks!
