Mainah
- Chapin, SC
- Limited S
Very helpful! Based on what you are saying I'm going to leave the control unit alone and focus on hose attachments.
I always run the blower until I have air bubbling hard from underneath the back of both tanks for a few seconds or longer, and then shut off both valves in one motion (with both hands). I assumed that would fill both tanks with air to capacity displacing all the water... I did notice the level difference but it was after the install crew already left. The boat is leveled side-to-side in the water with lots of stuff in the helm but dual batteries in the port comp, so the imbalance must be intrinsic to the lift.
The lift is rated for 6,000lbs IIRC and the size was recommended, I did not want to go smaller or "shallow water" model precisely to have some buffer. Well, maybe these boats are heavier than I thought the "wet weight" would be.
I will see what I can do!
Trying to picture your compensatory bucket devices, and imagine/figure out how does are installed and how do they work, but it must be too late... I'm going to have to look at it in the morning.
I bubble both of mine as well and shut off all tank valves before shutting off the blower. All with my rf remote control. When I set mine up both tanks raised evenly and reached the same height without the boat. With the weight of the boat that was not the case. I had not RTM since I was rebuilding with some custom modifications as I thought I understood all of the principles at play. Well I finally decided to track down and RTM. The part about the hose lengths needing to be equal side to side was quite clear and something I failed to consider on my own. Another key point is that the tanks should be the same height AND the boat should be level. Compensating for my hose length mistake took care of it. Unless there is extra hose under the water it appears that your hoses are not equal length. Understandable mistake for a computer geek like me but from what I have read an awful one for a professional installer. Either way should be remedied if the case.
