Texas_Transplant
- Scarab
- 255 SE
Hello, in some need of assistance regarding the wiring on the toggle switches.
I am adding in a LED drain plug light and want it to run off the existing 3 position switch for the docking/courtesy lights with 5 pins on the back, but I don't know where to tie in at. Right now the only thing I know is the center pin is the hot the top and bottom two pins both have multiple wires running into them so I don't know which one to tap into.
The switch is for courtesy and docking lights my boat does not have docking lights so both sides of the switch currently turn on the courtesy lights and that's it I would like one side to turn on just the courtesy lights and the other side to turn on both the courtesy and the drain plug light.
An easy way maybe to hook the plug wires to where the docking lights go (since I don't have them and assume the harness is just in the hull somewhere), but I don't know where to find it
